I noticed that a newer feature on the “Network Devices” tab makes it easier to add these checks to devices. Access a wizard based process in the south pane of this tab and chose Add Check --> SNMP Check. I’d like to know what are some common SNMP checks used by others and how does one go about finding the necessary OIDs or SNMP Index (specifically for Untangle). It looks like PFSense is one of the ones that is built in.
It is not a feature we are using extensively at this time.
