Small POE PD switch
I need some small footprint 8 port (or more) 1G or better switches to place behind a few TVs. I really want to use Unifi for the GUI/single pane of glass interface and ease of programming as I am not an IT professional.
The only Unifi option appears to be the ultra, but it has reduced L2 features. It also has the uplink port on the opposite side of the downlink ports, which is not ideal.
The Lite 8 port would be my next, but I really need to be able to power the switch off POE, and need 1 uplink and 7 down.
Am I missing any options?
The Ultra and the Flex are the only switch models that have PoE in and PoE out.
Okay, thanks. I thought that was the case. Wish they made an updated version of the Lite that could be powered of POE.
