Hi
I’ve deployed a Unifi Wi-Fi network in a school. There are 8 AP’s connected to a 16 port Unifi switch.
I’ve installed a Unifi UF-MM-1G SFP module into the switch. Its connected via a 30m fibre cable to the existing network.
On the other end I installed a TP Link Gigabit Media converter with a TP-Link SM311LM Multimode SFP module which is connected to a gigabit TP-Link switch.
Everything connected ok but I am getting slow network speeds and Internet speed tests are well below the rest of school even when connected directly to Unifi switch.
I have crossed the fibre patch lead at the TP-link converter.
Is there a setting I need to set on the Unifi switch to improve speeds or is having 2 different brands of SFP modules the issue.
My knowledge of fibre connections is limited so and advice would be a great help.
You could, but I’d say run a 100’ CAT6 between them to rule out the fiber. It could be a bunk media converter. Usually fiber is a bit of a “it’s working or it’s not” kind of thing.
