Site-to-Site OpenVPN with SSL/TLS in Unifi
I want to establish a S2S OpenVPN connection between pfSense and a Unifi Gateway, the server being in pfSense
If I create the server with shared key in pfSense, it tells you that OpenVPN deprecated peer-to-peer shared key and it will be removed. So you must use SSL/TLS.
On the Unifi side (Network version 10.0.162), I cannot create an OpenVPN Site-to-Site peer that uses TLS - it currently only supports shared key.
Is there a Unifi roadmap where they will support S2S OpenVPN with TLS?
What’s the best way to proceed? I don’t want to use WireGuard.
Thank you
Use Peer to Peer SSL/TLS in pfsense and then in the UniFI don’t use the Site to Site, instead import the pfsense settings into the “VPN Client” settings. Not sure why you don’t want to use Wireguard but just so you know it will be a lot faster if you did.
Some time ago, I did managed to successfully setup OpenVPN S2S between pfSense and UniFi (for some reason I did not managed to so what I wanted with Wireguard… but I don’t remember what exactly).
There where a few bump on the road… and this is what I remember:
As @LTS_Tom mentioned, you need to use Peer to Peer SSL/TLS
On UniFi side:
  • I used S2S OpenVPN
  • Cipher AES-256-CBC
On pfSense side:
  • OpenVPN Client Peer to Peer (Shared Key)
  • UDP over IPv4
  • AES-256-CBC as allowed algorithm and as fallback
  • Auth digest: SHA1 (that’s the default of OpenVPN and that’s what UniFi sticks too)
  • Compression: Refuse any non-stub compression
  • Also you will have to manually put some static route on your OpenVPN interface
Hope that help
Thanks for the comments… I ended up doing what Tom said and tried WireGuard and it worked…
Using a feature that OpenVPN already announced will be deprecated (Shared Key) was a non-starter, so I figured I’d give WG a try
It’s still hard to understand why Unifi won’t support OpenVPN S2S with SSL/TLS, this seems to be the way OpenVPN envisions the future…
Another gripe I have with Unifi is their OpenVPN server only allows TCP connections - a bit mind boggling actually
I want to revisit WireGuard for S2S as currently doing it vis IPsec. Works perfectly, but my understanding is WireGuard would be faster.
pfsense plus <> Unifi UCG Ultra
Use case is Synology replication atm
I have a gilet travel router via WG which works perfectly, multiple subnets, full tunnel and such
Yes, Wireguard will probably be much faster for that use.
Will give it a go and try and get the routing and such sorted. The reason why I wonder about the speed is the UCG-Ultra doesn’t have a particularly great CPU etc.
