Is there any reason i should consider moving away from a Sonicwall TZ570… The infrastructure behind it is all Unifi. I am at a k-8 school with approximately 300 students and 100 staff.
Am i losing on either end?
Usually the term “if it ain’t broke, don’t fix it” is the play. I’d say if you are proficient in the UniFi ecosystem and your sonic wall is reaching EOL or it isn’t giving you the features you want or whatever. I’d say switch it.
But if you are wanting to switch it just because, then it might be hard for the school to justify the cost.
What functions are you using on the sonicall and do you require them
Does Unifi have the same functions, so that you can move across to Unifi
