I have a Synology DS1815+ with lots of storage and I would like to set up shared storage that my two Dell servers can access. I know I can create a LUN for each but I would like to create a large LUN that both servers can access at the same time*for running VMs) and when I add more servers they can access the same shared storage LUN. I know some people have done this already I just need a bit of a push in the right direction.
I will be running MS Server 2019 on my servers.
So to recap I want to create some shared storage on the Synology DS1815+ that all my MS 2019 servers can store and run their VM’s in.
You could do iSCSI from Hyper-V to the Synology how you go about it exactly is all about how you deploy the Hypervisor. If it is your first time you could install the OS via GUI, however I would suggest you learn to do it with a core install (no gui) as it is the proper way to run Hyper-V in an Enterprise.
Also as a side note SMB 3 using RDMA via iWARP is the current best practice with Hyper-V.
Thanks for your response. I have already been able to spin up as many VM’s I have needed but I am trying to runs these in shared storage so I can put ALL VM’s in the same storage area and won’t have to set up a LUN for each server. I will keep looking into this and I appreciate your response. Thanks Jim
