Hi, as the title indicate says we want to install Access Points on our cold storage area but not sure if it’s ok or is there any particular access point to buy that can withstand the temps. Any tips would be very helpful. Thank you!
The data sheet says Operating Temperature -10 to 50° C (14 to 122° F) so it should be fine. We have not had any issues with the outdoor models here in MI where is get’s even colder.
Thanks for the feedback sir!
