Oh man, I have shot down my network after a move and unfortunately I can no longer access my backup files.
So I’d be super grateful for some tips on how best to set up my network.
I have the following devices:
Netgate Pfsense 6100 - each with two 10 GB ports, rest of the ports are 1 GB
Mikrotik 10 GB switch with 8 ports
Unifi 1 GB 24 port switch
I want to run two networks:
172.16.1.1 MAIN LAN
For my computers in my network, two computers are to be connected directly to the 10 GB switch, the rest will be 2 windows maschines and IoT devices
192.168.2.1
For my Proxmox hypervisor, on which several virtual machines are running (10 GB)
For my TrueNas server, which mainly contains video files that I edit directly there. (10 GB)
Both the Proxmox hypervisor and the TrueNas server are connected directly to the Mikrotik switch.
My question: how do I configure the LAN ports on my Netgate 6100 machine?
- Should I create two VLans?
- Which rule do I have to define in the firewall so that both networks can talk to each other?
- Or should I setup just one networkjto make life easier?
