Hi there,
im trying to up a truenas server on a vlan that is based from my lan interface with ID 5.
I have am using a netgear GS308E as my switch. (im hoping that is not my issue).
i have set the vlan to use 192.168.5.1 network.
im trying to set up my truenas server to use 192.168.2.23. my dhcp range is 192.168.5.25-192.168.5.50.
in my netgear switch I have set up the vlan settings to have port assignments for ID1: 1,2,3,5,6,7,5 and then ID5: 1,4.
port 1 is my link to my pfsense router, port 4 is what my truenas is connected to.
my truenas server has been given the dhcp address: 192.168.2.69.
i have the mac address of the truenas server set up as a static entrance on my vlan interface.
however every time i start my nas it automatically get the address from the dhcp server.
i have tried with the dhcp server enabled and disabled.
i have noticed that when i plug my laptop into the same port 4 it also get an address on the 192.168.2.1 network.
im missing something on setting up my vlan but i am lost as to what it is.
Under VLAN Membership, did you set port 1 as the tagged port and port 4 as the untagged port? Have you also gone under VLAN Configuration and modified the PVID settings? If your netgear switch is right after your pfsense box, then enter the VLAN ID you setup in pfsense for the PVID number for port 4 on your netgear switch.
it appears that i am now getting an ip address on another machine connected to that port on the vlan. but there is not internet connection or connection from other networks.
Well you tagged port on your netgear would be the port your pfsense box is connected with. Then your new VLAN tag 5 is you untagged port. Assuming that is what you mean with that you have it setup correctly?
so i was able to tag stuff correctly after @fusioncha0s said leave them untagged for the vlan and its finally working. its amazing! thank you all for the help. i swear i tried that one before but i guess not. just glad its finally working!
