Hi,
I have some docker containers running on my Synology …
I now access these through my NAS IP and add a port pointing to the specific docker container …
But I would like to give each docker container it’s own IP address (even each on a different VLAN), so I can isolate these dockers from the rest of my LAN and my NAS when opening them up to the internet …
I already do this with VM’s on my XCPng server, but I would also like to do this with my docker containers on my Synology NAS …
Can this be done ?
how ?
When the docker containers have their own IP (on their own VLAN), I could tell PFsense to grant isolated access to them from outside WITHOUT any danger of network hopping or any other danger … right ?
Cheers
Pascal
I have found some guides online where you create a new file and you specify a new vlan. Then you assign this VLAN to a container. Unfortunately these guides have not worked in my case.
Hi Guys,
I just had the displeasure of setting a syncthing docker up on my Synology NAS last night and while scrolling through the forums I noticed this post. I am happy to give you all a hand here. I too wanted the syncthing container to use a specific ip address on a seperate vlan than the Synology NAS.
The post that Spectre posted above is almost right but the command they advise to use to create the network is incorrect. I found this article that shows the correct command. Specifically it calls out the use of an actual ip address.
- To run this command you have to SSH into the Synology from the default admin account.
sudo docker network create --driver=macvlan --gateway=<gateway-ip-here> --subnet=<subnet-here>/24 --ip-range=<container-ip-address-here>/32 --o parent=ovs_eth0.<vlan-number-here> <network-name-goes-here>
- After you add the docker network you’ll need to reboot the NAS.
- Once it reboots sign into the NAS, open the docker app, navagate to the Network tab on the docker app.
- Highlight the new network that shows up and click the Manage button on the ribbon.
- Click the drop down menu and choose the docker container in question.
- Start up the container.
