Reference Tutorial: https://help.ui.com/hc/en-us/articles/218506997-Required-Ports-Reference
Protocol Port Direction Comment/Purpose
UDP 10001 Ingress Device discovery during adoption
I’m running a Debian VM and have the latest version of Unifi OS (with the latest version of the Network application) installed and running on it. I verified everything was working before I even installed the ufw firewall package.
I set up my UFW firewall rules according to the guide at the linked page. However, I think it must be incomplete.
10.10.10.16 is my U6 Enterprise AP.
10.10.10.20 is the Unifi OS server.
10.10.10.130 is a PC on this subnet that I use to access the web GUI for Unifi OS.
I have just a ton of this in my block logs:
[Sat Sep 12 22:40:40 2026] [UFW BLOCK] IN=ens18 OUT= MAC=$MAC SRC=10.10.10.16 DST=10.10.10.20 LEN=199 TOS=0x00 PREC=0x00 TTL=64 ID=65437 DF PROTO=UDP SPT=10001 DPT=59111 LEN=179
[Sat Sep 12 22:40:50 2026] [UFW BLOCK] IN=ens18 OUT= MAC=$MAC SRC=10.10.10.16 DST=10.10.10.20 LEN=199 TOS=0x00 PREC=0x00 TTL=64 ID=4206 DF PROTO=UDP SPT=10001 DPT=51451 LEN=179
[Sat Sep 12 22:41:01 2026] [UFW BLOCK] IN=ens18 OUT= MAC=$MAC SRC=10.10.10.16 DST=10.10.10.20 LEN=199 TOS=0x00 PREC=0x00 TTL=64 ID=6888 DF PROTO=UDP SPT=10001 DPT=46857 LEN=179
[Sat Sep 12 22:41:11 2026] [UFW BLOCK] IN=ens18 OUT= MAC=$MAC SRC=10.10.10.16 DST=10.10.10.20 LEN=199 TOS=0x00 PREC=0x00 TTL=64 ID=13691 DF PROTO=UDP SPT=10001 DPT=59107 LEN=179
[Sat Sep 12 22:41:22 2026] [UFW BLOCK] IN=ens18 OUT= MAC=$MAC SRC=10.10.10.16 DST=10.10.10.20 LEN=199 TOS=0x00 PREC=0x00 TTL=64 ID=16639 DF PROTO=UDP SPT=10001 DPT=55631 LEN=179
[Sat Sep 12 22:41:32 2026] [UFW BLOCK] IN=ens18 OUT= MAC=$MAC SRC=10.10.10.16 DST=10.10.10.20 LEN=199 TOS=0x00 PREC=0x00 TTL=64 ID=26985 DF PROTO=UDP SPT=10001 DPT=57192 LEN=179
[Sat Sep 12 22:41:43 2026] [UFW BLOCK] IN=ens18 OUT= MAC=$MAC SRC=10.10.10.16 DST=10.10.10.20 LEN=199 TOS=0x00 PREC=0x00 TTL=64 ID=37468 DF PROTO=UDP SPT=10001 DPT=34576 LEN=179
I’m not great at reading firewall logs, but what I’m seeing there is that my AP is sending UDP packets from port 10001 on the AP to random incoming ports on the Unifi OS server. I’ve also seen, to a much lesser degree, similar traffic attempting to come from the PC accessing the web GUI.
In any case, I don’t have a firewall rule for this. The only reference to Port 10001 is the ingress rule into Unifi OS quoted above. That’s not what this is.
Is this normal traffic?
If so, what is it trying to do? The AP is already adopted and working, so what is it trying to tell the Unifi OS server? The Unifi OS Network app knows the AP is there, so it’s not the primary heartbeat signal, I don’t think.
Assuming this is normal and we want to allow it, what do we need to add?
As a kludge: I’m thinking: “allow incoming UDP traffic originating on port 10001 from any source on this subnet.” That’s not ideal, and far more permissive than I’d like.
Preferred: “allow incoming UDP traffic coming in on $PortRange” and maybe optionally originating on the subnet from source port 10001.
The Question: What is $PortRange in this case?
I’d appreciate any help. ![]()
Aside from actually solving this problem: The referenced documentation doesn’t mention these ports at all under the section on the Network app, but also doesn’t include a section specific to UnifiOS as a whole.
What’s the best way to file a support request/bug request on the documentation with Ubiquiti?
