Does anyone know if there is a guide or some way to install the viewer for connectwise control/screen connect on Arch linux?
I googled around for the same thing and what I found was a reddit post linking to the Iced Tea version that worked with Control. Here is the link to the post,
https://www.reddit.com/r/Fedora/comments/uw11u2/struggling_to_install_icedtea_any_ideas/
This is for fedora but may be possible to use the rpm for Arch.
I honestly don’t like this solution and wish there was a better way to interface with Control from Linux. I was just at IT Nation and Linux desktop does not get any love at all.
If your workstation is beefy enough maybe going the route of a VM maybe the way to go. I am currently testing what is the best setup for Linux Desktop for my work environment.
I don’t use ConnectWise from home (Manjaro) very frequently but the last time I used it I found IcedTea didn’t work. I ended up going back to java 17 to get it to work again.
