Hi all, after a reboot yesterday, one of the pools in my scale system isn’t mounting correctly. The pool fails to import at boot, when I eventually get to the web-ui it’s stuck trying to import the pool with the following tasks:
When I SSH in and try to manually import the pool, including trying to overwrite the read-only status, I get the following:
cannot mount '/ssd': failed to create mountpoint: Read-only file system
Import was successful, but unable to mount some datasets
Once imported through command line, the pool shows up in the scale ui as do the datasets, but trying to look at the details of them results in errors:
Error: Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 198, in call_method
result = await self.middleware.call_with_audit(message['method'], serviceobj, methodobj, params, self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1466, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1428, in _call
return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1321, in run_in_executor
return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs))
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
result = self.fn(*self.args, **self.kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 191, in nf
return func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 53, in nf
res = f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/plugins/filesystem.py", line 430, in stat
raise CallError(f'Path {_path} not found', errno.ENOENT)
middlewared.service_exception.CallError: [ENOENT] Path /ssd/apps not found
I ran a scrub on the pool and that’s come back with no errors. The pool is an SSD mirror and both drives appear to be healthy.
zpool status ssd
pool: ssd
state: ONLINE
scan: scrub repaired 0B in 00:04:19 with 0 errors on Mon Nov 4 09:15:58 2024
config:
NAME STATE READ WRITE CKSUM
ssd ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
17f52ff9-6ac2-4f1c-8ee6-2bc722fc180a ONLINE 0 0 0
542085f4-905c-4154-979b-c0cbcd2c27a4 ONLINE 0 0 0
errors: No known data errors
Any ideas?
