Wasn’t sure which category to put this under… Anyway, I’ve got an Ubuntu box setup with a samba share on it and a user created and I can connect to it using my laptop (Which is not connected to a domain. This will come into play in a moment). I also have a server running windows server 2012 r2 that I am using SolarWinds backup to do offsite backup of and I wanted to use the samba share to send a local backup to using the LocalSpeedVault option they give in their software.
The issue I’m having is when I try to either connect from the server or in the software, it won’t take the username and password that I set up for the share. I was thinking maybe it’s an issue with SolarWinds backup but I can’t connect directly from the server either. I can browse to the IP and hostname of the Ubuntu box and see the file share but can’t successfully authenticate.
We have something similar setup on other servers using the same SolarWinds backup but have Synology NAS’ there instead and they connect up no problem at all.
Does anyone have some thoughts? I’m thinking I may just be missing something that needs to be set on the samba side of things or the auth in windows server maybe? I can get some more detail if some of this doesn’t make much sense, haha!
