Hey folks,
Planning to install an outdoor UniFi AP (the UAP-AC-M) at the back of my house for better coverage in the backyard and detached garage. I live in St Louis, where we get quite a few thunderstorms, so I want to make sure I do this safely. A few questions that I haven’t been able to find satisfactory answers to (will outline my full plan below, for context and hole-poking):
Do I need to have a lightning rod on my home before considering outdoor networking equipment?
Should I mount outdoor networking equipment on metal, wood, or plastic pole? My first thought was metal for rigidity and the ability to ground the pole once, and then ground devices to the pole. But I don’t want it to turn into an impromptu lightning rod that will fry the devices attached to it.
Can the UniFi surge protector live outside? Or do I need to put this in a weather-proof box?
Full plan: My network comes in via coax to a grounded connection at the back of the house (I’ll use this same ground point for the new outdoor equipment). Coax then travels along the exterior of my house to the front, where it enters my office. It’ll run through a coax surge protector (assuming this doesn’t severely hamstring my speed), and into a modem. I’ll use UTP CAT6 for all interior Ethernet runs. I’ll go from the modem to my home server (which will probably run PfSense on ProxMox), and then to a usw-16-poe. The switch will feed into an indoor NanoHD, and a shielded Ethernet keystone in the wall next to where the coax enters. I’ll then run shielded cable back along the exterior of my house to a UniFi Ethernet surge protector (grounded to the same point at the coax), and from there to my AP.
Bonus question 4: Eventually I want to mount 2 G4 camera on the same pole as the new AP. Seems easiest to run 3 separate cables, each with its own grounded surge protector. I could also run a single cable with a single surge protector to a USW Flex, and run all three devices off of that. Looking for the simplest/easiest solution here. Thoughts?
Thanks all in advance!
