Safe to run Pangolin VM with two networks (Internet + LAN)?
Hi, I’m looking for feedback on a Pangolin setup.
I’m planning to run Pangolin inside a VM that has two virtual NICs:
  • one connected to the Internet
  • one connected to my LAN
The idea is to use Pangolin’s local proxy / tunneling features to expose only specific LAN services to the Internet while keeping the rest of the LAN isolated.
My main questions:
  1. Is this dual-network VM setup safe, or are there risks of accidentally bridging/exposing more of the LAN?
  2. Is Pangolin designed to handle this kind of gateway/proxy role securely?
  3. Any best-practice recommendations (firewalling, network separation, etc.)?
For reference, here is my earlier post describing my environment and Proxmox setup:
https://forums.lawrencesystems.com/t/looking-for-feedback-on-my-proxmox-setup-in-a-datacenter-beginner/25944?u=mrab95
Thanks for any advice!
Yes, Pangolin should work for this and while it has been designed for this anytime you expose ports you increase risk as a flaw could be found in Pangolin or in what ever you are exposing behind it.
