Hi,
I want to destroy and re-setup my main pool on TrueNAS. I was wondering about the significance of the iocage dataset and found little about it in the TN documentation.
My questions is: I have zero jails running and the system dataset is set to the boot drive. There is an iocage dataset in that pool that I want to re-confirgure. Can I destroy that pool without messing up the TN system or is that iocage important even when you don’t have any jails installed?
Or will TN somehow “freak out” if I destroy that pool and set it up again (to update it to the new ZFS encryption etc.)?
Where do I even tell TN which pool to use for the iocage?
Many thanks!
