Running GrayLog on Synology
Hi Guys,
Has anyone used Synology and Docker to run a GrayLog instance for a small office - 70 users, 30 hardware devices). I know the Synology processor has to support AXD for MongoDB etc, so I would be running this on a higher end model.
I just wanted to get an idea whether it was a good workable solution or not.
Many thanks
IM
I should say it won;t be getting used for anything else beyond GL.
Not something I have ever tried but it should work provided the CPU has the mentioned support and overall it has enough speed. But generally the Synology line of hardware is just not that fast.
Thanks for the reply. I did suspect there might be performance issues.
IM
