Is there a way to get TailScale exit node traffic destined for the WAN to use a gateway other than the default?
Use case is that I’d like to have the convenience of being able to connect to my home network with the security of my NordVPN while travelling. I have a Nord Gateway set up within PfSense that I route select clients through using an Alias list, but can’t figure out how to route Tailscale Exit Node traffic via this gateway. TIA
Under the interface rules if you open up the advanced tab you can specify the gateway.
Tried that, and that’s exactly how I used to do it with Wireguard, it doesn’t appear to work the same way with Tailscale though.
Anybody? Surely there must be a way?
I’ve watched that video before, and can’t see anything in it relating to my issue
Bumping this up. I too am trying to set this up with TailScale. I’ve seen references to setting up this via VLANs. Tailscale doesn’t have interface.
