I need clarification on these synchronizing results,
[root@rockyidm1a etc]# systemctl status chronyd
● chronyd.service - NTP client/server
Loaded: loaded (/usr/lib/systemd/system/chronyd.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2023-04-05 15:18:23 MDT; 20min ago
Docs: man:chronyd(8)
man:chrony.conf(5)
Process: 1116 ExecStart=/usr/sbin/chronyd $OPTIONS (code=exited, status=0/SUCCESS)
Main PID: 1150 (chronyd)
Tasks: 1 (limit: 48624)
Memory: 3.7M
CPU: 61ms
CGroup: /system.slice/chronyd.service
└─1150 /usr/sbin/chronyd -F 2
Apr 05 15:18:23 rockyidm1a systemd[1]: Starting NTP client/server...
Apr 05 15:18:23 rockyidm1a chronyd[1150]: chronyd version 4.2 starting (+CMDMON +NTP +REFCLOCK +RTC +PRIVDROP +SCFILTER +SIGND +ASYNCDNS +NTS +SECHASH +IPV6 +DEBUG)
Apr 05 15:18:23 rockyidm1a chronyd[1150]: Frequency 8.230 +/- 0.248 ppm read from /var/lib/chrony/drift
Apr 05 15:18:23 rockyidm1a chronyd[1150]: Using right/UTC timezone to obtain leap second data
Apr 05 15:18:23 rockyidm1a chronyd[1150]: Loaded seccomp filter (level 2)
Apr 05 15:18:23 rockyidm1a systemd[1]: Started NTP client/server.
Apr 05 15:18:32 rockyidm1a chronyd[1150]: Selected source 107.155.79.3 (2.rocky.pool.ntp.org)
Apr 05 15:18:32 rockyidm1a chronyd[1150]: System clock TAI offset set to 37 seconds
Apr 05 15:32:35 rockyidm1a chronyd[1150]: Selected source 165.140.142.118 (2.rocky.pool.ntp.org)
the selected sources are,
however,
[root@rockyidm1a etc]# chronyc tracking
Reference ID : A58C8E76 (ns.august.tw)
Stratum : 3
Ref time (UTC) : Wed Apr 05 21:40:08 2023
System time : 0.000143721 seconds fast of NTP time
Last offset : +0.000076564 seconds
RMS offset : 0.000085321 seconds
Frequency : 8.221 ppm fast
Residual freq : +0.011 ppm
Skew : 0.230 ppm
Root delay : 0.057729453 seconds
Root dispersion : 0.017027335 seconds
Update interval : 259.2 seconds
Leap status : Normal
Reference ID is
This is the reference ID and name (or IP address) if available, of the server to which the computer is
currently synchronized.
and the selected sources of Ricky is not listed here,
[root@rockyidm1a etc]# chronyc sources
MS Name/IP address Stratum Poll Reach LastRx Last sample
^+ 108.61.23.93.vultruserco> 2 7 377 67 +521us[ +521us] +/- 67ms
^+ mail.trafficsystem.com.mx 2 6 377 5 +56us[ +56us] +/- 49ms
^* ns.august.tw 2 7 265 73 -900us[-1046us] +/- 58ms
^+ 143-42-229-154.ip.linode> 2 8 377 11 +742us[ +742us] +/- 88ms
What is causing the different select source results and if not normal, how can this be corrected?
