@LTS_Tom Curious if you are using N-ables implementation of S1 or using standalone S1 dashboards. I am trialing S1 thru N-able but the dashboard sucks pretty bad.
I look forward to your response. Thanks
Their integration does not give you the S1 dashboard.
Right. Their integration is terrible is what I meant. For instance no matter what I set my policy to, it only allows kill and quarantine, I can’t hot remediate or roll back on the n-able implementation and support is baffled.
We don’t use it via N Able anymore.
Thanks for taking the time out to respond to me tom. I appreciate it.
