Steps for a novice user on how to setup network (maybe via iptables) on a linux (ubuntu) box to be able to connect and maintain VNC connection which maybe connected to VPN
Here is an example say you have a box with IP 192.168.1.XY (can connect to it via VNC) and then as soon as it connects to say NorthVPN (or any VPN) connection is lost or can not be established. Thx in advance.
Why don’t you set up an OpenVPN server at home ? Then you can dial into that and access your home network and any device on it. If that device happens to be connected to a paid VPN when you remote into it so will you.
But it’s far easier to just set up VPNs on your router and just access the device on your vpn vLan.
Are you actually limited by the number of simultaneous VPN connections for your paid VPN provider and trying to mitigate that ? Are you trying to use your paid VPN when you are remote ?
If the answers to the above are yes then it’s doable.
Tom has several videos on OpenVPN, paid VPN, DNS etc. they all give you some clues.
Though I have to say it took me 3 months to move from my 10 router set up to pfsense.
Good idea to keep notes and back up your settings constantly, you will almost immediately forget how you solved a problem when faced with it again 1 week later
good luck
