Hi. I’m about the replace my Sonicwall with a Unifi Dream Machine Pro Max.
My question is…what is the best way to configure the Dream Machine while in the Sonicwall network? Should I plug the DM directly into my Modem? Should I setup a temporary VLAN to use as the WAN for the DM while setting it up?
If possible UDM having it’s own public IP would work because you can’t feed the WAN of the UDM with a network that will also have to exist on the LAN of the UDM.
Thanks! One more question. We have several ports where the port is connected to a 3CX desk phone internet port and then the user’s workstation ethernet is connected to the 3cx desk phone’s pc port. We are switching to Unifi switches from Aruba switches at this same time.
Is there a specific way I need to set these ports up so that the phone gets an IP from the phone VLAN and the workstation gets an IP for the LAN?
There should be a DHCP option you can set so the phones know what VLAN they need to be on. Then you would set the native VLAN to be the workstation and also allow the VoIP VLAN.
Alternatively there is a way to create a profile and set the VoIP VLAN. But I have had issues in the past and went down the path of setting the DHCP option for the phones. This way it always knows what VALN ID it needs to connect to. I think there was some weird timeout for the LLDP-MED and it would sometimes not work properly.
Is it normal for the Unifi console to show the phone as having an IP from the Native VLAN, which is LAN, even though the Phone has an IP from the VOIP VLAN?
In my testing that is what I am seeing. I tried it both ways you recommended. For both ways the Unifi console shows a Native VLAN IP address for the phone.
It’s possible because the phone is getting an IP address on that port along with the workstation connected to the phone. I think it’s a race condition to which gets an IP first. Not necessarily what is native.
This shouldn’t be, if the phone is grabbing an IP from the native LAN it’s on the native lan. Seems your phone is not getting it’s VLAN, check the settings on how your phone is getting its VLAN set. I use Unifi Gateways and Switches all the time with phones (multiple brands of phones) and have no issue in the exact scenario you describe
Ok thanks. the 3CX dashboard shows the phone getting the correct IP from the Phone VLAN, it is just in the Unifi Console does it show the IP as the Native VLAN. I’m going to be making some changes this weekend. If it continues after the changes I will let you know.
