Using pfSense on old Dell PC.
Only need about 7 total ports for my home network, but currently only have 4 port NIC.
So I used a small basic switch with VLAN capability.
Would there be any benefit by adding another 4 port NIC and eliminating the switch?
Say…speed … flexibility?
IMO, with a small setup, I think your switch would work perfectly. I’m running more of a production infrastructure and have 3 physical NIC’s in my main pfBox. My remote sites are using 2 physical interfaces. I have 2 Unifi 48-port POE switches that have no throughput issues with what we do here on 1 interface in pfSense. Hope this helps you some!
If devices of the same network don’t need to communicate with each other (i.e. only with other local networks or with the internet → all the traffic has to go through the router anyway), then I don’t see a downside. But if for example you have a workstation or server connecting to a NAS, that traffic would now go through another computer instead of through a switch. Switches are purpose-built for forwarding traffic and can do that in hardware. A computer running a software router cannot switch packets at the same rate, so there will be a bottleneck.
