I would like to access my Wiki and osticket that is running on a Synology server from outside of my local network. I do not want to have to type in port numbers. I have a fixed IP and running DDNS. I can edit and know how to edit my DNS settings. I can use a SRV record to get to a port on my network. How do I change the ports for the two applications? is there a better way? I can do a vpn into the local network but would also like to type in our web address then Wiki after it.
Setting up an OpenVPN connection is probably your best option, if you have DDNS or a fixed IP, you have all you need. I would guess that Synology has an option for VPN if you don’t have it on your router.
I think Reverse proxy is the best answer.
If you use a reverse proxy won’t that expose your services to the internet ?
Not sure that’s the best idea with these NAS devices, have a QNAP and they have had security issues over the years.
I use both a reverse proxy as well as an OpenVPN server to allow me to connect to internal services remotely while using a domain name.
That sounds more secure…
Zerotier… On which Tom has a video.
