First I’d like to say thanks for this forum and your YT videos. Very helpful! Second, sorry for the long post for a seemingly simple question.
I am struggling to determine the best ethernet cable to use for PoE Unifi cameras. I am replacing old networking equipment and an old security camera DVR with Unifi equipment (in my home). This includes a UDM-Pro, a USW-Pro-24-PoE, and a UNVR. I have 5 wired cameras that include 2x G4 Dome, 2x G3 Pro, and a G3 Bullet. There’s also a smart flood light in the mix too and I will add more cameras at a later time (perhaps 2 more).
The ethernet cable to connect the cameras and flood light will be routed through attic space and PVC conduit on the outside of the house. It will be routed near electrical wiring in some areas in the attic. The longest cable run is around 120 feet.
My current security cameras suffer from interference - from what source I’m unsure. They are wired with a combination coax/12-volt power cable. I want to avoid interference with the new cameras.
It seems as though Cat 5e or 6 cable would suffice for bandwidth. What about the jacket and shielding? It seems best to go with a plenum-rated jacket. Is F/FTP shielding overkill? (foil shielded with foil shielded twisted pairs) Or would S/FTP or SF/FTP be best?
Finally, it seems to be very difficult to find shielded bulk cable in less than 1000ft lengths. I only need around 250 feet and I was planning on terminating the cables myself. Are there reputable cable suppliers (in the US) that offer quantities of less than 1000ft? I found 250ft offered by WarehouseCables.com but it is only F/UTP. Perhaps that’ll work? The other option would be to find pre-terminated cables that are close to the lengths needed for each run.
Thanks in advance for any guidance!
