14 inch depth with storage is going to be hard to find, mostly those are going to be more like 24 inch deep. HP DL360e with some drives might be a good option (Gen 9 or newer is better than Gen 8).
There are a few 1u short depth Supermicro servers that will hold 4 laptop size drives, but getting them with the drive cages is hard to find on the used market. For Supermicro I suggest X9 or newer series of main boards.
Thanks for that. Not seen bargainhardware before - awesome
Your answers have helped a great deal in terms of narrowing in on what I need. I have a synology nas that serves as my media server. But running plex and an nvr is likely but not huge amounts of storage required. NVR only requires 48hrs of footage so 1TB is enough.
The key thing needed is the processing power and potential to add VMs. Further I am not planning on building myself and would prefer off the shelf options.
The HYVE branded servers on the used market are typically Supermicro X9 series in a short depth and 1u size, but they probably only have a single system drive installed. Would be decent for a hypervisor in the lab coupled with an external NFS/SMB share for the vitrtual machines.
I actually have an HP EliteDesk G3 Mini PC that I bought to “experiment” with using Proxmox. It works okay but nothing like my HP DL360 G8 or DL380 G9 - but those are much larger (and longer) and power hungry. The model you spec’ed above has much more horsepower (and two NICs ) which will probably work fine. Just get a 1U shelf and “Bob’s your uncle”. With electrical prices some days I would like to have something smaller than the Proliants.
