Hello Everyone -
Happy Wednesday!
Sorry if this is a silly question (if it is, please delete it) but BLUF is that I was wondering:
When creating VLAN’s and assigning them to a physical interface (which I think end up become sub-interface, e.g. em3.30) what should I do with the physical (e.g. EM3) interface, IP wise? In my setup I currently have EM3 enabled and set with no IP, and a sub-interface VLAN (30, which is sub-interface em3.30) configured and I think this configuration is causing me issues (more on that below) with DHCP static mappings.
More details:
I know I can’t disable EM3, that seems to disable the sub-interface too. I have no need for EM3 to have an IP address. When I start to get into static DHCP mappings I get a weird error that my static mapping “must lie within the EM3 subnet”, but EM3 has no subnet set and I’m working on a static mapping for em3.30 not EM3… so I’m thinking I’ve got something odd left over from a random change I made in my config file or more than likely: I’ve misconfigured something.
My setup:
I’ve setup pfSense to be a router on a stick in that I am rocking an HP thin client with a four port NIC which is connected to some Netgear managed switches, which are setup with VLAN’s (10, 20, 30, etc.). Everything seems to work (Routing between VLAN’s works, the switches are VLAN tagging correctly, DHCP is giving me addresses as I would expect, etc.). VLAN 30 is 10.30.0.x/24, and the DHCP server is configured to hand out address from 10.30.0.10/24 to 10.30.0.100/24. When I start to poke around with static mappings in the DHCP configuration page, I get an error message that doesn’t make any sense to me (“must lie within the EM3 subnet”) because the IP I am setting is within the em3.30 subnet and outside of the DHCP scope for em3.30 (10.30.0.105).
The reason I think I’ve borked something is because despite me working on the DHCP static mapping for em3.30, the error message isn’t about em3.30… it is about EM3. EM3 has no subnet (it isn’t configured, at least not in so far as I can see) so I’m a little lost.
Thoughts?
Thanks for your time in advance!
CricketNE
