Hi, so i am looking for recommendations, any help much is appreciated.
My situation is as following:
I have two locations, they are across the street from one another, with 200 meter distance and with clear sight. One place has 500 mbit/s up and down of witch I am using daily maybe about 10%. And other has none, so instead of subscribing to a 4G internet that would cost me about 260$ a year, I thought, that I could make a PTP (point to point) link between these locations.
So my question is what PTP antennas would you recommend. The internet speed is not really important, because it would be used primarily for security and surveillance.
And the price of the antennas also is not important, because I need a reliable connection.
It would be a long therm investment, so hopefully it would pay off after some years.
Thanks!
