Hello all,
I recently spun up a server node with a fresh installation of Proxmox however, when I tried to build out a ZFS pool of 10 drives I would get an error. When I sorted by “Serial”, in the GUI, the disk serial numbers are the same between 4 of the drives (highlighted in red). Why is the serial the same between these particular drives?
For a more granular exploration to the problem I decided to SSH into the server and ran the following command:
root@Newton:~# udevadm info -p 'block/sdc' --query all
P: /devices/pci0000:00/0000:00:02.2/0000:02:00.0/host0/target0:0:2/0:0:2:0/block/sdc
N: sdc
L: 0
S: disk/by-path/pci-0000:02:00.0-scsi-0:0:2:0
S: disk/by-id/wwn-0x502b2a201d1c1b1a
S: disk/by-id/scsi-3502b2a201d1c1b1a
E: DEVPATH=/devices/pci0000:00/0000:00:02.2/0000:02:00.0/host0/target0:0:2/0:0:2:0/block/sdc
E: DEVNAME=/dev/sdc
E: DEVTYPE=disk
E: DISKSEQ=11
E: MAJOR=8
E: MINOR=32
E: SUBSYSTEM=block
E: USEC_INITIALIZED=5697461
E: ID_SCSI=1
E: ID_VENDOR=ATA
E: ID_VENDOR_ENC=ATA\x20\x20\x20\x20\x20
E: ID_MODEL=KINGSTON_SA400S3
E: ID_MODEL_ENC=KINGSTON\x20SA400S3
E: ID_REVISION=0004
E: ID_TYPE=disk
E: ID_SERIAL=3502b2a201d1c1b1a
E: ID_SERIAL_SHORT=502b2a201d1c1b1a
E: ID_WWN=0x502b2a201d1c1b1a
E: ID_WWN_WITH_EXTENSION=0x502b2a201d1c1b1a
E: ID_SCSI_SERIAL=50026B728234D063
E: ID_BUS=scsi
E: ID_PATH=pci-0000:02:00.0-scsi-0:0:2:0
E: ID_PATH_TAG=pci-0000_02_00_0-scsi-0_0_2_0
E: DEVLINKS=/dev/disk/by-path/pci-0000:02:00.0-scsi-0:0:2:0 /dev/disk/by-id/wwn-0x502b2a201d1c1b1a /dev/disk/by-id/scsi-3502b2a201d1c1b1a
E: TAGS=:systemd:
E: CURRENT_TAGS=:systemd:
It seems as though Proxmox uses the ‘ID_SERIAL_SHORT’ field to populate the ‘Serial’ info in the GUI. My question is, how do I fix this issue with /sdc, /sdj, /sdm, and /sdn with the same serial number?
