Process Unifi syslog messages in Wazuh
Hello,
I don’t know whether I should place this in Cyber Security or Networking and Firewalls, but I start here.
Wazuh doesn’t process Unify syslog messages out of the box, as far as I know. Has anyone got it to work? Any links to a source that can explain how to do it?
Thanks.
I have only used Graylog, never really tested with Wazuh also not sure if it is really capable of that task.
At the core Wazuh is endpoint-based and the threat intelligence it has is based on endpoint detections. If you integrate Unifi logs you’ll have to write the parsers yourself and since it’s opensearch it’s a bit more difficult to get these working as opposed to Graylog.
