Hey everyone,
So I am currently trying to add a new XCP-NG host to an existing pool.
Here’s a rundown of what I did since install:
- Update host via
yum update - Add new host to XO
- Add SMB ISO Library
- First attempt at adding host to pool… yielding this error:
pool.mergeInto
"sources": [
"a2283b02-34ee-99e4-ddca-6799c721a07b"
"target": "f83f0e0c-e231-e93b-1335-171f672f0e62",
"force": true
"code": "JOINING_HOST_CANNOT_CONTAIN_SHARED_SRS",
"params": [],
"call": {
"method": "pool.join_force",
"params": [
"REDACTED 1ST HOST IP",
"REDACTED USER",
"REDACTED PASSWORD!"
"message": "JOINING_HOST_CANNOT_CONTAIN_SHARED_SRS()",
"name": "XapiError",
"stack": "XapiError: JOINING_HOST_CANNOT_CONTAIN_SHARED_SRS()
at Function.wrap (/opt/xo/xo-builds/xen-orchestra-202107111601/packages/xen-api/src/_XapiError.js:16:12)
at /opt/xo/xo-builds/xen-orchestra-202107111601/packages/xen-api/src/transports/json-rpc.js:35:27
at AsyncResource.runInAsyncScope (async_hooks.js:197:9)
at cb (/opt/xo/xo-builds/xen-orchestra-202107111601/node_modules/bluebird/js/release/util.js:355:42)
at tryCatcher (/opt/xo/xo-builds/xen-orchestra-202107111601/node_modules/bluebird/js/release/util.js:16:23)
at Promise._settlePromiseFromHandler (/opt/xo/xo-builds/xen-orchestra-202107111601/node_modules/bluebird/js/release/promise.js:547:31)
at Promise._settlePromise (/opt/xo/xo-builds/xen-orchestra-202107111601/node_modules/bluebird/js/release/promise.js:604:18)
at Promise._settlePromise0 (/opt/xo/xo-builds/xen-orchestra-202107111601/node_modules/bluebird/js/release/promise.js:649:10)
at Promise._settlePromises (/opt/xo/xo-builds/xen-orchestra-202107111601/node_modules/bluebird/js/release/promise.js:729:18)
at _drainQueueStep (/opt/xo/xo-builds/xen-orchestra-202107111601/node_modules/bluebird/js/release/async.js:93:12)
at _drainQueue (/opt/xo/xo-builds/xen-orchestra-202107111601/node_modules/bluebird/js/release/async.js:86:9)
at Async._drainQueues (/opt/xo/xo-builds/xen-orchestra-202107111601/node_modules/bluebird/js/release/async.js:102:5)
at Immediate.Async.drainQueues [as _onImmediate] (/opt/xo/xo-builds/xen-orchestra-202107111601/node_modules/bluebird/js/release/async.js:15:14)
at processImmediate (internal/timers.js:464:21)
at process.topLevelDomainCallback (domain.js:147:15)
at process.callbackTrampoline (internal/async_hooks.js:129:24)"
- Removed SMB ISO Library… fixing the above error
- Second attempt at adding host to pool… yielding another error (the one I’m stumped on):
pool.mergeInto
"sources": [
"force": true
"code": "POOL_JOINING_HOST_MUST_HAVE_SAME_DB_SCHEMA",
"params": [
"5.601",
"5.602"
"call": {
"params": [
"REDACTED USER",
"message": "POOL_JOINING_HOST_MUST_HAVE_SAME_DB_SCHEMA(5.601, 5.602)",
"stack": "XapiError: POOL_JOINING_HOST_MUST_HAVE_SAME_DB_SCHEMA(5.601, 5.602)
I’ve done some research and referenced the documentation from XCP-NG and XO:
Yet I’ve still yet to come up with a solution/answer.
Has anyone else seen this in the wild? Any advice on where I should look things up? Any ideas as to why this may happen? Thanks in advance.
