I have a UniFi 24 (250W) Switch and I keep losing connection to the CloudKey. If I unplug the CloudKey and plug it back in, the device comes back on-line. Obvious answer is replace the CloudKey (and I will). But I was looking for a way to power-cycle a port on the switch. Is there a way to do this?
Thanks for any feedback (and lack of any snarky comments) you may have.
Can’t the cloudkey be powered from usb too? If so, have you tried just using a phone charger on it, to see if it will run stable on that. Maybe it is just the POE part of it failing.
I should have added that I am trying to do this to reboot a cloud key if it is unresponsive. Am able to SSH into the controller and I was wondering if I can cycle a port via ssh command.
