Nowhere I have searched, nor any of the videos I have watched, mentions about multiple macvlans, or even any notes of requirements or limitations. Whenever I try to setup a second macvlan, I get an error saying “network dm-xxxxxx” is already using that interface.
My question is if it is possible to have multiple macvlans pointing to different subnets on the same ethernet interface?
I am using an Intel NUC Extreme. Only one of the 2 ethernet ports appear to be detected. That one is the 2.5Gbps Intel. The 10Gbps Marvell is the missing one. Being an Intel NUC, I would have thought (& hoped) both would have been Intel interfaces.
Well, one thing I was doing wrong was I needed to set static IP address for the container in when setting up the container (kinda defeats the purpose for getting it’s own MAC address for using DHCP reservation in pfS to set the static IP. lol)
Another thing I learned from the video is the Portainer GUI has limitations, & I should learn to do most (if not all from SSHing into Docker). It would also be better for me to learn to use Portainer’s Stacks, if I’m to use Portainer to deploy containers.
I also have more studying on properly setting up & deploying said network types.
Thank you
PS. Do you also think he has some ADHD? Or do you think it’s too much coffee?
That being said, nobody can complain his videos are boring.
