Anyone here use any of the Platinum Tools network test devices? I need something a little better than the simple continuity/short/cross tester that I have and started looking for “budget” tools (not Fluke). Stumbled onto to the products from Platinum Tools and thought I would ask. The up to 20 ID devices would be welcome, as would some of the features in the upper end tools.
Product pages:
Most simple that I would buy https://www.platinumtools.com/products/testers/vdv-mapmaster-3-0-cable-tester-t130/
The one I’d really like https://www.platinumtools.com/products/testers/network-testers/net-chaser-ethernet-speed-certifier-network-tester-tnc950ar/
Comparison chart https://www.platinumtools.com/upload_doc/1573057280ComparisonChart-P%20_102419_WEB.pdf
If you’ve used one of their products, I’d like to know your experience.
