Hi
I’m trying to get my head around VLANs.
Is it possible to connect everything physically to a switch that has VLAN management and then logically configure the ports to change which router
For example I have a 48 port switch, a VDSL modem which uses a tag of 101. I have 2 routers which runs pfsense.
You can have one logical port on a device and then assign multiple VLANs to that port.
Thank you
So would a trunk or hybrid port not strip the vlan tag that my isp has set
LTS_Tom
#4
Trunk should allow the VLAN tag to pass but many switches only allow VLANs that are defined in their config to pass.
