PHP CVE “php2shell”
This seems to be a pretty big deal. I hope everyone that sees this patches their hosts as soon as possible.
Should add that there is a node.js CVE out too. Patched my Xen Orchestra last night for node.js and my Opnsense for php.
The only website we have is on a shared host, so that company has put a mitigation in place while they patch, and claim over 70% of all hosts have been patched since yesterday.
The only thing I’m concerned about is KASMweb, I’m not sure if it is php or node.js running the web interface. Going to block the access port for now until I can deal with updating it.
I had the same worry with a small php admin panel last month it was still running the vulnerable version after the vendor said they patched it I ended up putting a temporary iptables drop on the port until I could verify the binary was rebuilt edit always double check the exact component version before assuming the host is safe
Half of my work’s website is down, I assume a patch didn’t go well. My hosted app is still down, working on my own fixes today parallel to the hosting company.
My KASM server is going to stay blocked until I have time to recover and check it out. Low priority right now because I don’t use it very often.
[edit] OPNsense had another php update that should be applied if you are on business. Missed this one on Friday, guess I’ll leave the cron job running to update things over night until (if) we get back to normality.
