Help.
- I have a Netgate 6100 firewall. I have FIOS 1Gbit up/down
- PfSense has a direct connection to my ONT. My Verizon router, old black one, is bypassed.
- Day-to-day FIOS speed is symmetrical at 940 up/down.
PROBLEM:
Around the 25th of each month +/- (or around my billing cycle) my connection becomes ASYMMETRICAL with 230-330 up and 940 down (via Speedtest).
Verizon’s own speedtest will show 940 down and then up will ramp up to 800-900 and then FAIL at 98%. This has happened once a month (always around the end of the month) for the past 6-9 months.
TYPICAL FIX
Take the 6100 out of the loop and connect the Verizon router directly to the PC and hard wire a PC to the Verizon router
Take 6100 out of the loop
Connect Verizon router to ONT
Connect PC to Verizon LAN port
Unplug ONT and Verizon router for 1 - 2 minutes
Pray
Wait until I see symmetrical speeds return
Take Verizon out of the loop
Plug 6100 back into ONT
Everything works for another month
Sometimes I will run into problems rebooting the Verizon router and will have Tech Support help resolve any issues. The problem with Verizon Tech Support is you never know if you get someone who completely understands or someone who just wants you to upgrade your service.
The typical fix is a mix of steps Tech Support has had me take before. Honestly, I am not sure if re-introducing the Verizon Router back into the system helps or not.
NEW PROBLEM
The typical fix no longer works. New ONT (same model) did not help. Tech Support is tech support in name only now.
pfSense is up to date. 24.11
I tried releasing and renewing DHCP lease.
I tried rebooting my router.
All in coordination with ONT reboots.
Chat and Claude both suggest it could actually be an OLT to ONT issue due to “speed-policy” being sent once a month. I dont know.
And, Verizon took away the ability to put my old Verizon router in bridge mode to pass the IP through to my pfSense like I could with my Orbi (just a year ago).
Thoughts?
