Hello,
I watched Tom’s video on How To Create pfsense Let’s Encrypt Wildcard Certificates using HAProxy and I have also watched the troubleshooting video. Maybe I am not understanding or have missed something.
My original setup was as follows:
sub.domain.xyz - pointed to the WAN_IP of pfsense firewall rule permitted only specific networks to access the web management gui. The web management gui was encrypted using wild card SSL. Life was good. Default port 443.
My needs have changed and I need to have remote access to an internal server. I tried the port forwarding but that was cumbersome. So I researched HaProxy and see that it can be used as reverse proxy and provide SSL encryption for remote sessions and pfsene when accessing the internal server. It can also point to a sub2.domain.xyz using the same WAN_IP.
Currently I can only access the web management gui via sub.domain.xyz:10443. And I cannot access my internal server.
pfsense 2-4.5-P1 with haproxy-devel 0.62_2
Backend:
Internal server
Server list:
active NAME 192.168.50.3 80 (no SSL) (no SSL checks)
assigned client certificate from lets encrypt.
Front end:
WAN Address (Listen address) port 443 SSL Offloading (checked)
type (http/https(offloading)
Access Control lists
Name internal server expression host matches value (sub1.domain.xyz)
Actions
Use backend internal server
Is there anyway to reverse proxy the management web gui?
