I thought Wireguard would be a bit faster and I think I heard you say that since the shared key mode was going away in 2.7 for OpenVPN it was preferable to do the switch to Wireguard.
If you are using shared key for OpenVPN, then yes that is getting deprecated. It is a bit faster, but most people are limited by their internet connection speeds more than their VPN unless you are running it on lower end hardware.
Noted. They are all running on custom firewalls with enough power for sure. Wireguard seemed cleaner to configure then OpenVPN with TLS I will weigh my options.
I did test it already with 3 virtual firewall in a mesh configuration. Wasn’t too bad but I see what you mean with all the routing and addressing it gets complex really quickly spacially for the first time. Thanks for the heads up. I’ll retest some more to make sure. Have a nice weekend.
