Just saw the pfSense/untangle comparison and I am currently running pfSense.
I’m thinking of adding untangle to my network for its logging and reporting features, but keeping pfSense on the edge for pfblockerNG so I can have ip based blocklists. Question for anyone with a similar setup:
I can go either dual Nat or put the untangle box in as a bridge. If I do use the bridge, what apps (besides the obvious - VPN) will not work? Don’t tell me dual Nat is the end of the world - I’ve done it before, it adds minimal latency delay, and all you need to do is forward anything you need for open ports from the edge box.
If I install as a bridge, I will have to setup the untangle to bridge the VLANs that it will be exposed to as it will be connected to a trunk port - again, any issues with applications?
Third option - put untangle on the edge if it has the ability to add and manage IP blocklists - from what I have seen there is only URL based blocking with the web filtering but would be happy to find I was wrong.
Thanks!
