Hi, I am trying to understand what I am doing wrong.
I am simply trying to understand why Nvidia Shield and Chromecast works on LAN interface and NOT any VLAN.
All VLAN are created on Pfsense and configured on UNIFI switch.
I have a pfense as router and firewall
w/ POE unifi switch connected via 10G link and also a UDM PRO connected to the switch.
DHCP runs on pfsense and Network controller on UDM PRO with option 53 DHCP.
Any device on my LAN can ping and cast to both Shield and chromecast soundbar when everything is on LAN, but as soon as the devices are moved to a VLAN (both Shield and Soundbar and laptop wired via ethernet) That laptop can ping but cannot cast.
No blocking rules on VLAN.
Holding complicated question for later, but simply put why & how can debug this mystery that devices on LAN can cast but not on any VLAN.
This issue is not yet about cross VLAN casting, but about casting to devices on the same VLAN
I have watched most of @LTS_Tom videos to setup the network.
I don’t have chromecast or similar, but from memory, the avahi package overcomes the cross vlan issue. I thought mdns doesn’t go through the router, hence you can’t see the other vlans, hence the need for avahi. At least that was my sketchy understanding.
