I have a couple of Blink XT2 cameras routed through Unifi to Pfsense and Open VPN.
The cameras won’t connect to their servers, so am unable to set them up.
I have a separate IOT net configured on Unifi with Chromecast, SmartThings etc which works fine.
Just can’t these bloody cameras to work!!
Any Ideas anyone?
Do you have policy routing? Also, it doesn’t make sense that you need to turn off the vpn for them to connect. If you turn the vpn back on after connecting them, you are technically not routing it over the vpn because the state to route them out whatever you have configured is still active (your wan as an example).
