Hey all! I have a PFSense 2100sg & my dad has a UDM Pro at his house. We both have static IPs. I am .10 & he is .200 for subnets. We currently allow all traffic.
I would like to create a subnet for my smart TVs, this subnet I would want to make them think that they are actually at m Dads house, to trick them into allowing me to use his Hulu at “his location.”
I have two problems doing this. 1) I have not been able to make a different VLAN WiFi work because I have my Unifi AP Pros plugged directly into the sg2100 because I dont NEED a switch. But, evidently, I should get one? Then I can tag appropriately? Am I unable to tag the ports on the sg2100 to the ap? I have watched Toms & Mactelecoms videos on VLANs & I have thoroughly check everything on this, too. My unifi AP can even ping the gateway on the other VLANs, its just if I make a network then wifi, DHCP will not give out. Yes, DHCP is on. Firewall rules are in place, otherwise pinging would not work.
- How will my routing work? How will I trick the device, say on VLAN 20, to think it is at my dads on the other end of the tunnel?
Thanks in advance! Keep networking!
