Can I restore a config file saved from an older Netgate device to a Newer one? Part 2: if the Older Netgate device had 2 WAN ports and the Newer device only has 1, what LAN port will it assign as the second WAN port? Any help will be appreciated! Thanks.
Yes, when you apply the config to the newer netgate and reboot it will prompt you on what ports you want to move them to. Make sure you are consoled to see the prompts.
