Anyone who successfully have connected pfsense with PIA vpn using WireGuard?
Do you like to share the procedure? ![]()
(I’m aware of the PIA openvpn knowledge article, but I do prefer WireGuard due to its simplicity)
Thanks.
Thanks.
Tom, has this video https://www.youtube.com/watch?v=ulRgecz0UsQ - working openvpn with PIA
As you are asking, wireguard can not be simple it you are asking for instructions
You’re right👍🏼. Resource efficiency is a better word in this case.
Yeah, Tom have several superb videos about PIA configuration. Though, not any that advocate for the wireguard setup. Probably for a good reason
. It may not be supported officially?
I have the same question.
I have been looking all over the forums, and PIA, but just cannot figure out how to setup PIA WireGuard VPN tunnels on my pfSense+ router using the addon pfSense WireGuard Package 0.2.1. .
I want to switch to WireGuard from OpenVPN as it seems to be the faster, smaller footprint, newer tech that will eventually displace OpenVPN.
I am using a SG-2100 on release 23.09.
Anyone have a working solution?
Thanks.
let me share two links:
Yea, tried to use those instruction/scripts last night but wg-quick and wireguard-tools packages are required, and I could not find them in the pfSense repositories. I do not know if they would work in pfSense in any case. Beyond my ability to go further on those.
In case anyone still wants to do this, I was able to configure my pfSense to connect to PIA using WireGuard.
Steps:
1 - Use scripts from GitHub - pia-foss/manual-connections: Scripts for manual connections to Private Internet Access to connect to PIA. Just clone the repository and run ./run_setup.sh
2 - Follow the setup steps from #1 and the scripts will generate a file: /etc/wireguard/pia.conf
3 - Open this file on a text editor. You will find the following information for you to configure your WireGuard tunnel and peer through the pfSense Web UI:
Address: 10.1.149.3 (or whatever is in your pia.conf). You must use this address on a NEW pfSense interface you must create (make sure to select static IP address for it) which is associated with the WireGuard tunnel.
PrivateKey: xxxxxyuyyyyyyxxxyxyxyxyx → you will use this during the creation of the new WireGuard tunnel in pfSense. Enter this on “Interface Keys / private key”
Peer config:
PublicKey: xhxhxhxhxhxhxhxhxxhxh → copy and paste this to a new peer you’re associating with your newly-created WG tunnel
AllowedIPs: 0.0.0.0/24 → copy/paste on your new peer
EndPoint: somePIA-FQDN.com:1337 → copy and paste this to your new peer. Make sure you de-select dynamic endpoint
4 - You need to configure outbound NATs on pfSense using the new interface for all traffic from 192.168.1.1/24 (or whatever your LAN network address is)
5 - You need to configure a gateway for your new interface.
6 - Use policy routing to route all traffic from your LAN (or desired network) to the newly-created gateway from #6.
Hope this helps, it’s working for me. With WireGuard I can get 900mbps down and up from PIA, rather than the ridiculous 300mbps I was getting with OpenVPN connected to the same servers.
ive got a config via the github instructions and tried it on pfsense… the tunnel is showing up but i’m not seeing any stats against the interface… i have a pia vpn setup via openvpn client and it works fine… ive tried adding a rule and also to nat outbound and tried with one of my lan devices but it shows as my normal wan address… what am i missing… should the interface for it be set to dynamic which is what it defaults to … ?? i already have wireguard working as a remote access to my home LAN…
thuis is what the pia.conf file created based on my username and password…[Interface]
Address = 10.22.x.x
PrivateKey = UA3 etc etc
DNS = 10.0.0.243
[Peer]
PersistentKeepalive = 25
PublicKey = dhZW etc etc
AllowedIPs = 0.0.0.0/0
Endpoint = 138.x.xxx:1337
Because the private keys and server IPs on the PIA side change from time to time, I realized using WireGuard in pfSense w. PIA is very unstable. What I ended up doing is creating a very slimmed down VM with Debian, configured it to be a gateway and just added one of the IPs from the VM in pfSense as a gateway… Then the Debian VM manages all changes in WG settings by using PIA’s own scripts so I’m not stuck to pfSense’s implementation of WireGuard
@cjmdk Not sure if you are still looking but the guys at Mullvad have a great guide for getting Wireguard setup on PFSENSE. I followed their guide, but also applied Tom’s OPENVPN Privacy VPN with a Kill Switch instructions to keep that capability. It works great! I have not come across any other WireGuard VPN providers that have a good setup guide for wireguard with pfsense, but you might be able to apply this to your PIA setup.
