I have an issue with adding an additional interface in pfsense. I have done this on 1 different port and everything works fine, Its the same hardware as the working one.
When trying to get out to the internet I cant, and the following have been done/checked
Firewall rule has been added and is correct (same as working interface)
Outbound NAT is setup and in automatic mode
I can ping the interfaces static ip that is assigned but cant ping for example 9.9.9.9
When I look at the states table for that interface I see the ICMP state for interface IP but I do not see the state for the 9.9.9.9 ping.
In pfsense under diagnostic->traceroute and source address OPT1 interface, it does a traceroute fine.
I am stumped and any help in this matter would be really great. Any logs I should look at? Could it be a bad interface?
I didn’t need to specify any gateway for other interfaces/networks, the lan interface doesn’t have anything? This in essence is another lan type interface. According to netgate lan type interfaces don’t need an upstream gateway. What gateway would I put into there? Thanks for your help Tom.
I misread and thought you were trying to create a second WAN interface, I will assume that you need to make sure you have the proper firewall rules in place for that new interface to pass traffic.
Also, a word of caution in case this wasn’t clear to you: From the description you gave the rule it seems this should allow traffic from the test net to the internet, which it technically does. However, it also allows traffic from the test net into any other local net! This might be what you intended, but I noticed the discrepancy and thought I’d let you know.
