Hi There,
I am getting the following error in the system log.
| Jan 13 08:02:13 | php-fpm | 319 | /vpn_openvpn_server.php: The command ‘/usr/local/sbin/openvpn --config ‘/var/etc/openvpn/server1/config.ovpn’’ returned exit code ‘1’, the output was ‘Options error: In [CMD-LINE]:1: Error opening configuration file: /var/etc/openvpn/server1/config.ovpn Use --help for more information.’ |
| Jan 13 08:02:13 | php-fpm | 319 | OpenVPN failed to start |
| Jan 13 08:02:13 | check_reload_status | 358 | Reloading filter |
I am not seeing any errors in the openVPN log area. I have the logging set to 10 and can’t figure this one out. I tried to create a new VPN and it does the same thing.
Is there a system check that will check over all services and files in pfSense?
Thank you
