I’ve setup pfsense on Virtual box and for some reason the DNS resolution does not seem to be working unless i have the gateway (of the physical router outside the vm) added into the DHCP server. Ping seems to be working from the pfsense box but not from the client.
Moreover the “Allow DNS server list to be overridden by DHCP/PPP on WAN” has been checked so wouldn’t that mean the pfsense would use the DNS from the WAN interface.
Adding the routers IP to the DNS server in LAN>DHCP Server works but is that the correct way to do it. Wouldn’t that bypass the pfsense if i want to force all DNS queries to go through pfsense.
Following your video on blockin all DNS queries and adding replacing the ‘pass’ rule with a custom one solves it but just need to know if that is how it should be done.
