Hi,
Great community here and have learned a lot from Tom and reading through these forums.
Have an issue with multi-wan failover. So setup multi-van failover (WAN_FAIL) and set the default IPv4 gateway under System → Routing. I thought that worked but when WAN1 would go down, it would freeze any online videos or gaming.
So, reading Pfsense documentation, they say that the Default gateway under System → Routing is for the firewall’s access to the Internet and not necessarily user data. So then I went to the firewall rules and set the “Default allow LAN to any rule” rule to use the WAN_FAIL gateway (Firewall → Rules → LAN). After doing this i was unable to access a vlan called DEV. I had to explicitly put in a rule to allow LAN-net to access DEV-net. When i set the default gateway back to default i can access the DEV vlan without the new rule.
Questions:
1 - Why did i loose access to the DEV vlan after setting a default gateway in the firewall rules to WAN_FAIL?
2 - Why did MDNS stop working when i set the firewall rule "“Default allow LAN to any rule” to use WAN_FAIL as the default gateway?
3 - Am i even doing this properly - all i want to do is make sure the connection is not interrupted when WAN fails over and still have access to the other VLAN?
Thank you in advance.
